Alpine 3527 wont turn on but power goes to it
Username: F6mafia
i have a alpine 3527 and there is power that goes to it but it wont turn on and i cut all of the wires off so im pretty sure it isnt shorting and i used a meter and there is like 12.35 volts going into the amp and it has a good ground do you have any ideas???
Username: Zdubb
Post Number: 8
Does it have a remote terminal? You'll need something hooked to that to get the amp to turn on
