Help with HDTV
Username: Doug0305
I need some help. Ever since I got HD, the security cameras I have run to my tv's don't work. What I am being told is that the bandwidth is so great for the HD that there is not enough room for the signal from the cameras to come through. Does anyone have any suggestions as far as a filter or a switch or anything???
Username: Cableguy
Somewhere on... U.S.
Post Number: 881
The best thing I could offer would be to run a dedicated line from your camera system to any available input on your TV. If you're currently injecting your video stream into the coaxial RF cable, more then likely you are being told correctly that it will not work. It's not so much of the bandwidth issue as much as it is about the frequency your camera is transmitting it's signal at vs the frequencies your cable signals are using.
Username: Doug0305
thanks cableguy
