Does a sealed box hit the lows better than a ported??
Username: Pike110
12w6v2s, Indianapolis...
Post Number: 284
I was at a local stereo shop and the guy told me if you want to get really low you have to go sealed????
Username: Bump05
We Stay Fly, 18 SX USA
Post Number: 362
na i say ported 27hz gets low low sealed hits a more punchier bass that gives more sq
Username: Pike110
Post Number: 285
I am kind of new to box making. Is it standard the more port area you have the lower the tuning goes?
Username: Bump05
Post Number: 364
im not sure i understand...
what sub?
how big of a box can u make?
and ill tell you
Username: Redliner
Wilmington, Ma
Post Number: 3337
sealed plays a flatter tune then a ported box so it kinda depends on how u have your ported tuned if u know what i mean someone correct me if im wrong
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 1557
to me sealed sounds like a more controlled or constant sound. it completely depends on the sub in order to know what box will be best for it.
Username: Gh0st_31
FL USA
Post Number: 69
if you want it low, jsut get a ported box and tune it low
Username: Basshead86
FTW
Post Number: 9347
here's the thing....the lower you tune a ported box, the less control the sub has at higher freq. so there are trade-offs. :-)
Fi AudioBTL
Post Number: 7669
hitting low really depends on the sub. some subs hit low really well while others don't.
FTW
Post Number: 9372
indeed it does Chad, good point.
but if you want balanced output across the scale, and don't want to sacrifice "muddy" :-) sound in the upper sub bass region, go sealed. imo
Username: Extrmndor3
Im pushing i... And pushing ...
Post Number: 2804
ported and try to make round ports instead of flared for alil more good soundidn sound and port free noise.
yeayyyyyy go ports.
Post Number: 2805
why not try both???
ask who made this set up he got both of them and it looks like he can hit the lows pretty good.
:-) once again Mr. Rob for all of ya .
yay with these two set up forget about steve meades, they are gonna b@ng him like a noob.
Username: Safe_cracker
Chicago, IL US
Post Number: 2122
"hitting low really depends on the sub. some subs hit low really well while others don't"
Technically any sub can play a 1hz tone, not that hard to do but how much power is required to keep it in control is design dependant. Depending on size, shape and tune a ported enclosure has the potential to be LOUDER not deeper. A ported box may loose control at higher power levels due to the loss of acoustic suspension. Because a sealed box retains its acoustic suspension throughout its entire playing range that will allow it to play through a much more vast set of frequencies which would only be cut by subwoofer design limitations. I would say a sealed box will play lower but if the same sub in a box able to play equally low the ported box would be louder. Polo.
FTW
Post Number: 9391
^^^^ j/k polo. :-)
Chicago, IL US
Post Number: 2131
J/K Muddy :-O Polo..
Username: Tanmanfosho
C Bang, Hardcore Iowa USA
Post Number: 30
can anyone tell me what spl, and sq means
<<<<noob
Username: J_baby15
Kentucky
Post Number: 1013
sound pressure-spl, loudness
sound quality-sq, how good it sounds.
Post Number: 34
thank you
FTW
Post Number: 9416
lmao
