lost TVI + Jeya TV. First I got blind screen ad I was waiting for autorole. nothing happened. I checked with the pagedown key nothing happened. So must be the channel moved. I checked the NIMIQ2 Settings:
Trans. 12253/v/20000/auto LND Freq: 11250 Normal Auto LNB4 OFF
Look gus you have the wright TP Freq. They are still at Nimiq 2 Channel 707. Just do a TP scan only for that} 12253. If you can't get that to work do a factory setting will delete all your channels. Then do a blind scan
