Is that a LH550SB? I have an LG LH550TB that I have just successfully unlocked. You could try this method as it could possibly also work for the S550SB, if that's what you meant to type.
open tray using remote enter 0000 TV screen should show Region Edit and Region Code enter 0 in Region edit then press Enter Press Pause then Power When Powered on all regions should play
