SVR or Kinetic
Username: Alexv305
Tavernier, FL USA
Post Number: 484
Im lookin into buying some batts.
Should I get the Kinetic HC2400 or the SVR 100-12.
Here are the links
http://www.svrbatteries.com/battery_page.php?bid=26
http://www.kinetikaudio.com/hc2400.asp
What one can handle more power?
Username: Adddisorder
West palm, Florida
Post Number: 2707
no contest the kinetik beats it in all aspects
Username: Alexv305
Tavernier, FL USA
Post Number: 485
Well actually the SVR puts out more amperage so there it is...
West palm, Florida
Post Number: 2711
kinetik doesnt list the MAX amps only amps and the svr only has MAX amps listedm, so there it is...
either one is decent so just go with whatevers cheaper but id still take kinetik
Username: Johnfiac
IL Afghanistan,...
Post Number: 949
just by the specs they listed on the SVR compared to the Kinetics id say Kinetics is better.... Good brands dont need to list every spec... Max Amp... CCA...ect just the specs that you really need to know. BTW the Kinetics would prolly have a higher floater voltage ;)
