i have bought the null cable.. i want to know what i must do before i connect the reciever to the pc.. do i have to erase everything on the reciever first or not? also when i connect it to the pc.. should i plug it to the electric or not and also the switch on the back of the reciever should be on or off.. thanks
Do a factory reset in the menu ,then hook up receiver to pc null modem cable turn receiver on,install bin/file wait till it has completed ,then turn off ,do your settings and blind scan.Don't be afraid u won't hurt anything.
