Do i need special keys for ppv?
Username: Andrewmenia911
Post Number: 19
hey guys.. i want to know.. if i locate my dish at echo 7 or the 119 west.. and i entered the new key for dishnet.. well the ppv channels work or i have to put new keys or bin for the ppv channels?
Username: Maryvazq
Puerto Rico
Post Number: 538
Depends on your receiver. there are ones, like Microyal, that doesn't have a Bin. If your receiver already have a bin, only with changing the keys should be fine. If you have missing channels, then re-scan your receiver...
Post Number: 20
well i have pansat 2700A.. well i didn't upload any bin yet cause i just ordered the null cable from the internet.. but i was wondering if i uploaded the 288 bin would make the ppv channels work free?
Username: Maryvazq
Puerto Rico
Post Number: 542
Yes!!!. Just install it. It's working fine for me. I have a tutorial in PPoint but in Spanish. Maybe it woul be useful to you. Is a visual tutorial. Follow the steps not the words. It should be fine for now
application/x-zip-compressedUpload
Ayudita-247891.zip (64.4 k)
Username: Osc
PUERTO RICO
Post Number: 397
There's only 1 ppv in sat 119 if you want to catch them all the ppv you need to add sat 110 and of corse flash the new bin
