I need Diagram for 98 nissan Maxima w/Bose factory syaytem
Username: Linbckr35
I need help bad! I have a 98' nissan Maximaw/ factory Bose system but i want to replace the factory headunit with my Diesel Audio Tv/Dvd/Cd player, but i need to bypass the factory amp some how. Can someone please help. If you can please email me the information. Linbckr35@aol.com Thankyou!!!
Username: Leew
XXXX!!WWWW, Yokosuka, ... SPESNAZ. ...
Post Number: 898
Well Dwight R. Hicks,you cannot bypass the factory Bose Amp in 1998 maxima! coze there is no Amp at all!!! Each speaker got separate Amp!You have to change OEM speakers along with your Diesel Audio Tv/Dvd/Cd player or whatever you you want to put!
P.S.just let me know,if you still need that wiring diagram...I'll give ya for nothing!!
Username: Linbckr35
Yea i still need the diagram. but wat do you mean that i have to change OEM speakers? Do you think its a good idea to just hook up my Bose speakers to a 600 watt amp and push it lik that? Or should i just go out and by new speakers?
Username: Aleut
You have to change OEM Bose speakers! Go to Jennifer web,the schema is there !
Click here!
BTW.Jennifer will back friday
Username: Linbckr35
what are good speakers to replace the OEM speakers in my car? And do I have to replace the tweeters too? Or can i connect that also to my amp?
