110+119 with Pansat clone
Username: Jowhar
Post Number: 75
I do have pansat clone with 110 and dish pro two lnb and I will like get a 119, is that I have to put 119 program in to My receiver plse help.}
Username: Satscanner
NDS Laboratory
Post Number: 289
You will need a second lnb,attached to the left side of your existing lnb.You can do this by taping,nylon tieing,hose clamps ,whatever works for you. leftside looking from behind reflector plate.Attach cable rg6 coax to the lnb and switch.If you are going to add more sats later use a diseq switch. If u just want the two sat's,use a 22kz tone switch,better switching .In the antsetup menu add sat echo7, set lnb freq:to 11250 standand lnb, set diseq 22kz ON if ur using a tone swich,if a diseq set to the number port of the switch input, then blind scan,watch tv.
Username: 18_volts_baby
Super Moder...
Post Number: 110
[Link Removed]
