Gold Member Username: Extrmndor3Friday, Str8t to the Gentlemans club Post Number: 2711 Registered: Feb-06 | well i juzz received my 50 feet of 0 gauge cable and i juzz redid my big tree and i made two runs one for pos and one for neg, do i leave it like that or should i make two runs of positive and put the negative on the chassis??? aight people thanks |
Gold Member Username: Van_manBoston South, MA Post Number: 1361 Registered: Mar-06 | Check out a grounding spot with a DMM. If you have a clean path, I would use chassis. Then check the 0/1 with the DDM. See which is better. Setting the DMM to read ohms, and obtaining the lowest reading possible is the best, wether wire or chassis. Im sure ppl will have feelings both ways. But if your Bat - to chassis is tight, and amp to chassis is tight, go with it. |
Gold Member Username: Van_manBoston South, MA Post Number: 1362 Registered: Mar-06 | http://www.proav.de/index.html?http&&&www.proav.de/data/wire-resistance.html |
Gold Member Username: Extrmndor3Friday, Str8t to the Gentlemans club Post Number: 2720 Registered: Feb-06 | wow thanks man but i dont get the link too confusing but thanks man |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 2085 Registered: Jan-06 | running a negitive run is probly a better ground then grounding to chasis. i remember B saying something like that. thats what he did in his lesaber |
Gold Member Username: Extrmndor3Friday, Str8t to the Gentlemans club Post Number: 2725 Registered: Feb-06 | well man i juz aded a kinetik hc600 and i still have dimming, bad luck uh?? |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 2108 Registered: Jan-06 | what is your entire electical set up lil rob and how much power you running anyway. |
Gold Member Username: Extrmndor3Friday, Str8t to the Gentlemans club Post Number: 2742 Registered: Feb-06 | 2800 rms, i have a red top front 180 amps alternator, 15.9 voltage ( i juzz remeasured juzz yesterday to make sure) at idle, and i juzz added a small hc800 kinetik battery oh 0 gauge knukoconcepts wire big 3 done under light neons and i still have dimming. i think im gonna replace my starting battery with a kinetik hc2400 |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 2126 Registered: Jan-06 | yeah after you put in a bigger kinetik you should be fine. but with what you have now it doesnt seem to be enough battery. |
Gold Member Username: Extrmndor3Friday, Str8t to the Gentlemans club Post Number: 2748 Registered: Feb-06 | i know man but its gonna cost me a nut almost 300 the cheapest that i can find, and im trying to get two of them so will be 600 and the kinetik close to the amp as posible |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 2130 Registered: Jan-06 | look on ebay they have good prices |
Gold Member Username: Extrmndor3Friday, Str8t to the Gentlemans club Post Number: 2755 Registered: Feb-06 | i know its gonna be like 290 shipped |
Bronze Member Username: James3146Portland, OR USA Post Number: 63 Registered: Oct-06 | If your battery voltage is 15.9 with the car on, then you are probably going to ruin the batteries. That isnt right. Unless you are running a 16 volt system which still doesnt sound right. Make sure the amp is not connected to the same battery as the lights, also consider a isolator or battery manager, those will charge both batteries. |
Gold Member Username: Extrmndor3Im pushing i... And pushing ... Post Number: 2829 Registered: Feb-06 | nope ur wrong, i always metered my voltage and always is 14 volts and up but never reached 16 volts, batteries are wired parralel, and its nto ruiinin my electrical plus whn i turn the car off my voltage stays at 13.5 volts and my voltage meter its on between normal and low when i turn my car and my voltage goes up my voltage meter statys to normal not high |
Bronze Member Username: James3146Portland, OR USA Post Number: 68 Registered: Oct-06 | If your voltage is over roughly 15 Volts then you are going to ruin the batteries. Depending on application 13.4 to 14.8 is normal operation for the alternator to charge at. |
