Pioneer SDP4053K Image Distortion Issue
Username: Rsloan
Greetings,
I was just given this rear projection TV... but it seems to have an annoying issue with the image. The bottom 6 inches is blank screen and the top 12 inches has horizontal black lines running through it (see image).
Can anyone help with this?
Username: Stevestar99
Dahlonega, GA
Post Number: 34
You've got some kind of vertical output failure. If you aren't a tech it's pretty hard to tell you how it fix it. Call around, it shouldn't cost more than $300.
