Dish91w
Username: Grub
Post Number: 8
where is 91 in comparison to 119? I remember a post on how to move from 119 to 91 but i cant find it any help would be great thks
Username: Grub
Post Number: 9
the post read 'stand behind dish and move it ?degrees up and ? degrees over'
Username: Abj
Post Number: 387
if you are standing behind the dish you should move it to your left.Without your location and type of dish you have , it is kind of hard to help you.
Username: Grub
Post Number: 10
i have a qsat dish in Canada
one pts at 110 one at 119 and trying to point a third at 91
Username: Abj
Post Number: 388
you should turn your dish to left as I have stated.Just litte more to you left from 110.Elevation ???.
http://satcalculator.freehostia.com/ you can find your elevation at this link.
Username: Grub
Post Number: 11
thanks so much for your help. i'll knock the snow and ice off it and try to aim it.
thks again
Username: Abj
Post Number: 389
good luck.........
Username: Vanticano
Can anyone lead me back to the threats posted a while ago about DVT LNBs to get DISH (1 disk shoot 2 sats, which sat is possible to get...) Anyone has docc of this topic to post? Appreciate.
