I've got a Hifonics Zues 2 Channel 400W Amplifier acually puts out 400w. I want to know a proper way to connect two 2006 Kicker Comp subwoofers in bridge mode. I've done it but I'm not sure if it's the proper way. And don't want to risk killing the amp. They just don't sound good when there hooked up into the two channels. Each channel puts out 200 Watts but they just are not sounding great. I've adjusted and tuned everything and it still it's just not the same with the 400W going to both. With the 400 going to both the bass is very crisp and clean. But seperatly it sounds like they don't have High intense hertz. And the low seems bland. Help me out? It would be great to draw a diagram! Thanks.
That would probably explain why the amp will shut off at certain high volume bass hit? I guess protection mode sets in. Is there anything I can do? I just wasted $150 On this amplifier!? It's not one of the newer models. Probably the 2002 Model it was cleaned out of Hifonics warehouse brand new. On the box it says this Min. Impedance Bridged: 4 ohms So that changes when I hook up Two 4 ohm subs? If there's nothing I can do I'm not going to be a happy camper.. GREAT RESPONSE though good lord that was fast. Help still needed!
Not the response I was looking for.. I'm going to hook it back up in bridge mode and really don't care if it blows up or not. Don't see how it RMS's 400W and it's not a Class D. I hope the thing burns up.
