Do all FTA receivers use 9 Pin RS232 Serial Null Modem Cable
Username: Mtkhan56
Mississauga, Ontario Canada
Are there any receivers that can be flashed via a USB cable.
Username: Nydas
Post Number: 990
Talal: You will have to buy a USB to 9 pin serial adaptor. This iwll give you a straight 9 pin RS232.
Username: Tetuscosmicus
Montreal, Quebec St. leonard
Post Number: 352
*Ariza Ultra 400/500, 700, & 750- Null modem cable
*Astrovox 2600-Straight through DB9
*Blackbird and all Blackbird clones(BOB, Max 1000, Stealth II. MS1000, ,etc.)- Null cable
*captivework 500, 600s, &600premium - null modem cable
-==Colsat 4000 Plus-Null modem cable
-==Colsat 4000 Pro. 5000 & 6000-Straight through DB9
*Cooltec-Sraight through DB9
*Coship (All)-Null modem cable
*Digiwave 6800/7000 & 7200-Null modem cable
*Digiwave Diamond-Straight DB9
*Dreambox (All)-Null modem cable
*Fortec lifetime-Straight through DB9
*Fortec Lifetime Ultra-Straight through DB9
*Fortec lifetime classic NA - null modem serial cable
*Lava 2600-Null null modem cable
*lava 3200- straight through db9 (ps2500A's clone)
*Max 2500-Null modem cable
*Megasat (All)-Straight through DB9
*Microroyal (All)-Null modem calbe
*orasat v3.0 &v5.0- null modem cable
*Pansat 2300a/2500a and all clones-Straight through DB9
*Pansat 2700-Null modem cable
*Pansat 3500-Null modem cable
*Pansat 5000HC-Null modem cable(Also can program through USB)
*Pantec/Multistar Max (All)=Null modem cable
*Pantec/Multistar MS (All except MS1000)-Straight through DB9 (ps2500A's clone)
*Pantec MX/Ultra-Straight through DB9 (ps2500A's clone)
*Rex1-Null modem cable
*Silver bullet/ST 1000/2000-Null modem cable
*Skyview 500-Straight through DB9
*Spacestar DVB500-null modem cable
*Stealth 2000a-Null modem cable
*Ultrastar 5000-Null modem cable
*Viewsat VS2000 platinum and extreme-Null modem cable
