Right now i have 3 dishes connected with a diseq switch leading into my house. i want to install a new receiver on another tv, my qustion is is there a way that i can't spit the cable in my house so that it then leads to 2 receivers. if so how can i do this and is there any downsides like quality loss or signal loss.
in other words wat i want is only one wire leading into my house then using some other switch that will split the cable in two so i can connect 2 different receivers on 2 diferent tvs.
