Connect pansat reciver to pc
Username: Andrewmenia911
Post Number: 15
can i use the printer cable to connect the pansat 2700A reciever to pc.. cause i can connect both by this cable but i don't know if it will work..
here is the pic of the cable
http://www.giddings.txed.net/aymalinak/equipment/printer_cable.jpg
Username: Minn_rock
Post Number: 891
""Pansat 2700a/e - Null Cables""
andrewmenia you have to have this cable,and that don't look like the Null Cables to me..
Username: Minn_rock
Post Number: 892
look like this 1..Upload
Username: Satscanner
NDS Laboratory
Post Number: 225
No way, that wont't even plug into a 2700a.You are pc ilertate,but something not adding up , even if have a pansat?
Post Number: 16
well i was only worndering if it might work.. but anyway i ordered the null modem from ebay and i'm expecting to recieve it at any time
NDS Laboratory
Post Number: 226
Sorry talking to andrew media.but u guys got it.slow posting /locking.
NDS Laboratory
Post Number: 227
What? you ordered the pansat, which I really doubt or you ordered a null modem cable on line which I doubt. Think about it people , usually LK will catch these frauds.But nobodoby can be everywere.
Post Number: 17
i ordered the cable from ebay
NDS Laboratory
Post Number: 250
Why ? any shipping is worth more than the cable at any pc shop,or electronics store and no waiting.
Username: Goat_skin
the cable cost like 10$ at the computer store why u want to order it?
Username: Nydas
Post Number: 980
andrewmenia: The cable you showed is an older type of cable that was introduced by IBM with the original IBM PC approximately 1983. It used the established 25 pin serial standard and the established 36 pin Centronics standard - married these two physical devices and created a parellel printer cable.
The old IBM PC standard for serial was a 25 pin RS232 cable - an established industry standard.
Later - In the late '90s the "IBM PC clones" standard changed to a 9 pin cable and that is what people have these days, and your receiver uses this standard.
Even later, a new standard, called USB (Universal Serial Bus" was introduced and some of the latest PCs come without the 9 pin serial.
There are two types of 9-pin cables (based on signals). One is a straight RS232 where pins 2 and 3 end up at the other end as pins 2 and 3. Another type is where Pin 2 ends up as pin3 and Pin 3 ends up as pin 2 - this is called the null modem.
Some receivers need a straight RS232 cable and some needa null modem cable. They have to be F/F, i.e. a female end at both ends.
