Archive through November 30, 2006
Username: Avis
Post Number: 11
LATEST DISHNET & BEV KEYS
DISHNETWORK
Key0: 6353EFF1783F84191476A0013BB3065C
Key1: 1EB3937A2C693424E43152C07C296356
BEV
Key 0- 08ED372E076BCF0049342594A2CF32E0
Key 1- 5D533A24072AAFB7C77924CF494B60ED
Username: Minn_rock
Post Number: 849
loader v27.01 for 284 and newer bins
you need this loader too.."loader v27.01 for 284 and newer bins"
vane lee..
Username: Lklives
Post Number: 6003
Anytime U have "issues" of ANY kind, ALWAYS REBOOT the receiver by switch in back OFF/ON for about 3 minutes..or UNPLUG, if U have no rear switch..
if that doesn't fix it, then factory default in menu, recheck antenna settings and make corrections if necessary, scan again, upload bin again and let keys autoroll (if its working), and then REBOOT receiver again...thats about all anyone can basically do..U can also download the latest bin again and upload THAT one instead of your bin (could have slight corruption)....THIS APPIES TO ALL RECEIVERS!!!!
Many sites have a section JUST for bin BUGS, which U can read also
Username: Tyger1979
Post Number: 12
MINN ROCK : can you give me the link to direct-download the bin "Pansat-C 2700 288v1 Tivo". i cant find the bin.
Username: Tyger1979
Post Number: 13
MINN ROCK : I got loader v27.01 from
http://www.orbidish.com/showthread.php?p=1882#post1882
now i need the bin that you gave me. i didnt find yet.
Username: Minn_rock
Post Number: 850
vane on the DSSROOKIE link go down to "FTA[FREE-TO-AIR]section..and look down u will see PS section...or go to this link it easier to find..
http://www.ftabins.net/forumdisplay.php?f=35
and don't forget the loader too.
Username: Tyger1979
Post Number: 14
MINN ROCK : im on my way.
Username: Minn_rock
Post Number: 851
x-87bl_061124_288_api2700.zip
http://www.ftabins.net/showthread.php?t=1316
vane
Username: Tyger1979
Post Number: 15
MINN ROCK : im on the link http://www.ftabins.net/forumdisplay.php?f=35
Im trying to find the bin Pansat-C 2700 288v1 Tivo
Username: Tyger1979
Post Number: 16
MINN ROCK : ok i got the bin .
thanks
Username: Tyger1979
Post Number: 17
i got the bin: x-87bl_061124_288_api2700.zip
MINN ROCK: how to download the bin to pansat?
Username: Tyger1979
Post Number: 18
what is the Download Procedure for Pansat 2700A.
i have loader v27.01 and bin
Username: Dude123
Post Number: 720
Vane lee
Pansat 2700 Programming Procedure:
• Hook up your receiver to the computer on the com port. Leave the receiver power OFF.
• Once hooked up turn the receiver ON.
• Open up the Loader. Then click on the bin file.
• Once you got that bin file then click open.
• After that download the bin file.
• Wait till the 100% file has been downloaded.
• You will get a message on your desktop "Download Completed".
• Your receiver power will turn OFF automatically and then will be turned ON.
• After that, unhook your receiver.
• Attach receiver to your TV.
• Type 8282, go to "set default key " click ok
• Then exit.
ENJOY TV
Username: Minn_rock
Post Number: 852
vane u need Pansat 2700a/e - Null Cables, a winzip or winrar to extract your bin file,disconnect the SAT cable from your box,open the loader,load the your bin file,turn off your box from the back of your box....press download on your PC in about 2 second,turn on your box from the back...and wait till it go to 100% and your box auto go off and reboot itseft..conncet your cable back in and wait for the autoroll roll the key...finish
Username: Minn_rock
Post Number: 853
The One good work man..Thanks man..
Username: Ardi
Hi guys .I am newbe here .
I am having problems with these keys
I have Ariza xtreme and don't have a section to close the auto roll
My questions are
I go to nagravision and have 010100 then I put the keys they don't work
Then there is bev provider keys of 0901 I am confused how do I put and save them
I will appreciate any help
Username: Bertoro
Toronto, Ontario Canada
Post Number: 411
70 18 84 62 6C D5 D8 F4 20 11 F1 5F E5 42 58 28
active01
Username: Lucia
Post Number: 325
ferenck those are not working.
Username: Avis
Post Number: 13
Key0: 701884626CD5D8F42011F15FE5425828
Username: Heyhowru2004
Active 00
1E B3 93 7A 2C 69 34 24 E4 31 52 C0 7C 29 63 56
Username: Kitu
Post Number: 14
Hola chicos, tengo una pregunta, acabe de ponerle el nuevo bin a mi pansat 2500a y no funciona, sera que tengo que cambiarle los codigos?? Gracias...
Username: Kitu
Post Number: 15
sorry guys, wrong forumm..
Can u guys post the latest codes.. thanks
Username: Aurora
Can you give the the first line of 5 lines on viewsat extreme for Dish 010100
00 I accidently erased it
08 I have it
09 I have it
88 I have it
89 I have it
Username: Aurora
For Viewsat extreme - dish 010100
00 I need this line
08 70 18 84 62 6C D5 D8 F4
09 20 11 F1 5F E5 42 58 28
88 1E B3 93 7A 2C 69 34 24
89 E4 31 52 C0 7C 29 63 56
Username: Ardi
Nobody is helping me
I have ariza extreme and don't know how to put 0101 and 0901 keys in it to make it work
Username: Kuluminati
Nagra2 Keys
Dish Provider 0101: Last Updated (Nov27 10pm EST)
Key0: 70 18 84 62 6C D5 D8 F4 20 11 F1 5F E5 42 58 28
Key1: 1E B3 93 7A 2C 69 34 24 E4 31 52 C0 7C 29 63 56
Bev Provider 0901: Last Updated (Nov27 5pm EST)
key0: E7 BA D0 C4 DB 45 AA CF B0 BA 62 E6 B8 9A 5E 3A (Active)
Key1: D1 4B 0E CC CA 61 62 A7 40 56 FE 67 91 61 25 1B
I'll keep providing as long as you enjoy and say thank you lolz
Username: Lklives
Post Number: 6007
Nagra2 Keys
(active)
Username: Tyger1979
Post Number: 19
MINN ROCK / THE ONE: I did step by step your instruction. i click to download the bin and nothing happend. I wait for 5 minutes. i got always 0%
look at the pic. Upload
Username: Minn_rock
Post Number: 855
vane.. do u have the right cable "Null Cable"..and change the serial port,COM 1 to COM 4,try all of them to see which one will download...if u don't have the right cable it will never download..
Username: Donnie1973
Tennessee
Post Number: 491
yeah, if ur using a usb to serial adapter for a laptop, it will be com 4.
Username: Captain_cook
new keys pls!
Username: Mc_sunny
Post Number: 787
Dishnetwork :11/28/06
Key1: DC2950C3B381C4B2AFD1468128104325 <-Active
Username: Martinpraguer
Bohemia
Post Number: 7
Dish 0101: Last Updated (Nov28 1pm EST)
Key1: DC 29 50 C3 B3 81 C4 B2
AF D1 46 81 28 10 43 25 (active)
Bev 0901: Last Updated (Nov28 1pm EST)
Key1: 02 AE C3 3E 9E 4C E1 74
A0 75 FF 9C 9B 65 D2 1C
(Active)
p.s. I believe you have to input only ("Active" key)
Cheers
Username: Mani01
anyone with bev keys
Username: Mc_sunny
Post Number: 789
Bev New Keys: 11/28/06
key 0: E7BAD0C4DB45AACFB0BA62E6B89A5E3A
Key 1- 02AEC33E9E4CE174A075FF9C9B65D21C <-Active
Nagra2 Keys
Dish Provider 0101: Last Updated (Nov28 1pm EST)
Key1: DC 29 50 C3 B3 81 C4 B2 AF D1 46 81 28 10 43 25 (active)
Bev Provider 0901: Last Updated (Nov28 1pm EST)
Key0: E7 BA D0 C4 DB 45 AA CF B0 BA 62 E6 B8 9A 5E 3A
Key1: 02 AE C3 3E 9E 4C E1 74 A0 75 FF 9C 9B 65 D2 1C (Active)
Username: Free2rhyme2
Current DISH Network NagraVision 2 Keys
IDEA KEYS: 11/28/06 @ 1:50 PM
Dish IdeaKey 00 (86): 70 18 84 62 6C D5 D8 F4 20 11 F1 5F E5 42 58 28
00: 70 18 84 62 6C D5 D8 F4
01: 20 11 F1 5F E5 42 58 28
Dish IdeaKey 01 (96): DC 29 50 C3 B3 81 C4 B2 AF D1 46 81 28 10 43 25 <--ACTIVE
00: DC 29 50 C3 B3 81 C4 B2
01: AF D1 46 81 28 10 43 25}
Username: Mc_sunny
Post Number: 798
Dishnetwork new keys: (2nd change)11/28/06
key 00 : DD122FA0396620D5D11E21DAD2B03720 <-Active
key 01 : DC2950C3B381C4B2AFD1468128104325
Username: Mc_sunny
Post Number: 799
Bev new keys (2nd change)11/28/06
key 0: 0CC6BE28A646F3FAFF5206EA2D549584 <-Active
IDEA KEYS: 11/28/06 @ 3:50 PM
Dish IdeaKey 00 (86): DD 12 2F A0 39 66 20 D5 D1 1E 21 DA D2 B0 37 20 <--ACTIVE
00: DD 12 2F A0 39 66 20 D5
01: D1 1E 21 DA D2 B0 37 20
01: AF D1 46 81 28 10 43 25}}
Username: Avis
Post Number: 14
new keys anyone?
Username: Zk44
Username: Trixxtor
Post Number: 8
new keys anyone
Username: Khaled2000ly
any news keys please
Username: Bertoro
Post Number: 419
C3 34 DD 88 03 1E C3 89 E5 DE 2E D8 9D 89 E7 76
active 01
Username: Creek
Smithtown, New York
Post Number: 340
Username: Avis
Post Number: 15
mine came back after scaning for a bit.
let it scan.
Username: Creek
Smithtown, New York
Post Number: 341
If you get the program keyripper v3.1 you will be able to generate keys without waiting. Do a Google search and get it.
Username: Pinkblush
Post Number: 17
thanks for the keys
Username: Avis
Post Number: 16
Creek;Thanks i did.
you can download it from [link removed]
I tried to attach it but it exceeded the maximum allowable upload size.
here the link to keyripper v3.1 [link removed]
}Current DISH Network NagraVision 2 Keys
IDEA KEYS: 11/28/06 @ 7:30 PM
Dish IdeaKey 01 (96): C3 34 DD 88 03 1E C3 89 E5 DE 2E D8 9D 89 E7 76 <--- ACTIVE
00: C3 34 DD 88 03 1E C3 89
01: E5 DE 2E D8 9D 89 E7 76}}}
Nagra2 Keys
Dish Provider 0101: Last Updated (Nov28 8pm EST)
Key0: DD 12 2F A0 39 66 20 D5 D1 1E 21 DA D2 B0 37 20
Key1: C3 34 DD 88 03 1E C3 89 E5 DE 2E D8 9D 89 E7 76 (Active)
Bev Provider 0901: Last Updated (Nov28 8pm EST)
Key0: 0C C6 BE 28 A6 46 F3 FA FF 52 06 EA 2D 54 95 84
Key1: C1 09 BD B5 21 69 27 FD 12 B1 14 30 06 81 68 6B(Active)
Username: Mont_eastwood
Post Number: 9
How to input the keys to Ariza 700. Can anybody help me with it.
Username: Minn_rock
Post Number: 866
Ariza 700 / 750cx changing Keys
Go to menu,
Go down to parental controls,
enter.....then press "i" buttoin on remote control,
then press 2004. that should get you into the coding system menus.
Go to nagra 2,
go dwn to key 00,
look for Dishnetwork a top. Type in key 00.
If you type in 8 number for key 00 and 8 for key01, it mite not work. Try that first.
Then if its dosn't work, type in all 16 numbers in key 00 (in the two rows), that worked for me.
Make sure to press OK button on remote after you type in each row, to save.
Then just exit till you see the picture
Username: Alibaba_can
Post Number: 28
Key0: 9B 5F A1 D5 EC 54 DB 7F E7 A6 68 EA F4 A2 28 BB
(active)
Post Number: 11
Thanks MINN ROCK.
I typed in all 16 digits key0 but it didn't work.
Then I put in all 16 digits in key1 but still it didnot work.
AM i missing some thing?
Username: Jalisco
Post Number: 19
NEW KEYS FOR NAG 2 PLEASE!
Username: Fgabaldon
Post Number: 54
00 --- 9B 5F A1 D5 EC 54 DB 7F E7 A6 68 EA F4 A2 28 BB
01 --- C3 34 DD 88 03 1E C3 89 E5 DE 2E D8 9D 89 E7 76
Username: Minn_rock
Post Number: 867
Sheraz Masood the keys had change again tonight,you need a new keys..and i waiting for the keys too..
Username: Atul_shah
Post Number: 9
Dish Network down with the following keys
DID THE KEYS CHANGED ???
Username: Minn_rock
Post Number: 870
Atul..
DN 00 9B-5F-A1-D5-EC-54-DB-7F-E7-A6-68-EA-F4-A2-28-BB...active
Username: Atul_shah
Post Number: 10
MINN ROCK it WORKS ..Thanks
Username: Dude123
Post Number: 726
Nagra2 Keys
Dish Provider 0101: Last Updated (Nov28 11:30pm EST)
Key1: 13 37 08 08 82 70 6B 49 E2 95 36 28 B3 6F B2 81(Active)
Key1: C1 09 BD B5 21 69 27 FD 12 B1 14 30 06 81 68 6B (Active)
Username: Avis
Post Number: 17
How do i block (with password)channels?
with aka Pantec 2500a ?
any idea?
IDEA KEYS: 11/28/06 @ 11:30 PM
Dish IdeaKey 00 (86): 7B 7F 5A 1A 49 EC 6F B7 01 B7 9F ED DD 4E 52 7D <--- ACTIVE
00: 7B 7F 5A 1A 49 EC 6F B7
01: 01 B7 9F ED DD 4E 52 7D
Dish IdeaKey 01 (96):13 37 08 08 82 70 6B 49 E2 95 36 28 B3 6F B2 81
00: 13 37 08 08 82 70 6B 49
01: E2 95 36 28 B3 6F B2 81
Username: Mc_sunny
Post Number: 821
Dishnetwork New Keys: Nov 29 2006
Key0: 7B7F5A1A49EC6FB701B79FEDDD4E527D
Key1: 9B9D9B5A480137E1869723BD713243F4 <-Active
Dish IdeaKey 01 (96): 9B 9D 9B 5A 48 01 37 E1 86 97 23 BD 71 32 43 F4 <--- ACTIVE
00: 9B 9D 9B 5A 48 01 37 E1
01: 86 97 23 BD 71 32 43 F4
Username: Shyi
Post Number: 10
DN keys: Updated Nov 29 ; 7:30PM
key 86: 33 64 16 BD DD DA 4F 7C B4 2D 00 77 32 DC 29 BD (Active)
key 96: 9B 9D 9B 5A 48 01 37 E1 86 97 23 BD 71 32 43 F4
Username: Atul_shah
Post Number: 12
Whats wrong with DN new keys don't work. I had
Username: Dude123
Post Number: 743
Nagra2 Keys
Dish Provider 0101: Last Updated (Nov29 9:30pm EST)
Key0: 33 64 16 BD DD DA 4F 7C B4 2D 00 77 32 DC 29 BD
Key1: 09 29 36 EE E8 72 D7 32 B2 44 5C 1D 2A 5E 02 45 (Active)
Bev Provider 0901: Last Updated (Nov29 1:30pm EST)
Key0: 91 0E 0F 56 03 23 06 D2 9A F8 6C 4E 49 4E F0 62
Key1: DD 16 AA 33 32 9C BA 4E BA 06 9B 48 C5 40 F6 63 (Active)
Post Number: 8
Dish Provider 0101: Last Updated (Nov29 11:30pm EST)
Key0: 7C D7 3B 68 E0 03 4F 60 65 84 2E 79 34 04 19 4E (Active)
Username: Jwl1
Post Number: 25
Those keys are not working for me. I even checked the second receiver to see if it was working (Viewsat with autoroll) and it is.
Username: Dizasta
keys r not working the last ones
Username: Ke5aqn
Shawnee, OK USA
Post Number: 72
if you checked a working receiver you could just simply look on that receiver for the working key's silly Joe
I have pansat 3500 must have had 4 key changes for DN today MOST I ever seen in one day and now at 11:50 OKLA time they changed again.....
Username: Jwl1
Post Number: 26
LOL...you would think so, as that is what I used to do. However, my son password protected it to keep me out of it. Sure, I could use the master code and get into it; however, he will know, since it will set it back to default THEN he will be really mad, which means when my box needs something, I'll pay the price for getting into his. :-)
Username: Ke5aqn
Shawnee, OK USA
Post Number: 73
LoL sounds like you need to work it out with him...I am still waiting for a pic on DN or new key to be posted lost BEV today as well the dish I use got knocked over in the wind and its snowing so i will wait.........and then....wait some more can you beleive 5 what 5 key changes TODAY for dish?
Username: Techjj
Hey all. This is my first post here. I've been reading these posts for a long time now and thought I ought to start puttin in my two cents once in a while. The first number in the second line is wrong. That's the prob with Joe Bob's latest numbers. Change the 65 to C5 and you should be good.
7C D7 3B 68 E0 03 4F 60 Key 00(active)
C5 84 2E 79 34 04 19 4E
Username: Bowmani
Post Number: 7
Thank you JJ :-)
Username: Puretrance
Montreal, Quebec Canada
Post Number: 14
Does anyone have the new keys for bev?
Username: Mc_sunny
Post Number: 831
Dishnetwork new keys: 11/30/06
Key0: 7CD73B68E0034F60C5842E793404194E
Key1: E9B014DE10FBF8EA3CB2F36C9647D81B <-Active
Username: Mc_sunny
Post Number: 834
Bev New Keys :11/30/06
key 0: F34DD5EACF16448134C9AB99BA6E0FFA
key 1: E81299BC397D35D7A1AFF143FCBFC33C <-Active
Post Number: 16
Thank you McSunny, much appreciated!!!
Username: Mc_sunny
Post Number: 835
Your welcome Enjoy ur Tv
Post Number: 19
Oh I will... Thanks again my freind!!!
Username: Mc_sunny
Post Number: 837
Bev New Keys: Nov 30 2006
2nd change
key 0: D0B238502E9A0CEF0AC1FC689B8B4141 <-Active
Post Number: 20
Thanks Mc Sunny. Why so many key changes all of a sudden?
Username: Mc_sunny
Post Number: 838
beacuse they don't want you to watch Pirate tv...they are losing business!!
Username: Techjj
I believe there's another change already. Those last numbers aren't working for me McSunny.
Username: Mikeyzoo
6C 3B 00 40 FA 57 4A E5 DA AD DE 9C 24 41 B8 3D
E9 B0 14 DE 10 FB F8 EA 3C B2 F3 6C 96 47 D8 1B
Username: Tasha01
Post Number: 15
I have a pansat 2700 (clone) receiver. Can someone tell which cable to use and where I can find a safe bin? thank very much.
Username: Houhou
Post Number: 11
new codes please ..
Username: Mc_sunny
Post Number: 844
Dishnetwork Keys Nov 30 2006
DishKey00: 6C3B0040FA574AE5DAADDE9C2441B83D
DishKey01: FBED0B75673EB5449629A8D132CC01CA <-Active
Username: Mikeyzoo
here we go again...
key (86) 00: D0B238502E9A0CEF0AC1FC689B8B4141
key (96) 01: 52ABB499F69BBF6E20EEC3008B1FF196
Nov 30, 1:15pm
Username: Mikeyzoo
last post doesnt work sorry
Username: Gusification
Post Number: 10
thats all there is nothing else?
Post Number: 11
keys rnt workin can anyone help?
Username: Bertoro
Post Number: 423
Key0: 6C 3B 00 40 FA 57 4A E5 DA AD DE 9C 24 41 B8 3D(Active)
Key1: FB ED 0B 75 67 3E B5 44 96 29 A8 D1 32 CC 01 CA (new)
Username: Homam
thanx ferenck :D
