Username: Teamdeboy1971 OPTIDRIVE LN.,
TN
Major Bass P...
Post Number: 407 Registered: Nov-06
Sunday, December 03, 2006 - 05:21 GMT Ok, this 15" sub seems to be a good sub from what i've heard! I don't get the QUAD 1 OHM VC?? What load amp would it take? or does it being a quad give you more voice coil configs.??? It says and I quote"3000RMS 6000PK, WOWWEE!! ARE THEY WORTH 400.00 EACH?????????????????????????????
TN
Major Bass P...
Post Number: 416 Registered: Nov-06
Sunday, December 03, 2006 - 06:14 GMT would it take a 1 ohm or a .5 ohm or maybe even a 2 ohm??
Username: Shortysetnies Rock Vegas,
NC
US
Post Number: 646 Registered: Mar-06
Sunday, December 03, 2006 - 06:17 GMT .25 or 4 ohm
Username: J_baby15 Kentucky
Post Number: 965 Registered: Feb-06
Sunday, December 03, 2006 - 06:22 GMT 4 ohm, 1ohm, .25ohm
TN
Major Bass P...
Post Number: 421 Registered: Nov-06
Sunday, December 03, 2006 - 08:04 GMT WOW, YOU SORTA Get a better selection with a quad coil! would it be ok to use 2 amps on a quad?
Username: Juliob Santo DomingoDominican Re...
Post Number: 3609 Registered: Dec-05
Sunday, December 03, 2006 - 13:52 GMT yes, you can do that Rob
Username: B101 DD, RE, FI, TREO, KICKERUSA
Post Number: 4029 Registered: Sep-05
Sunday, December 03, 2006 - 14:10 GMT you can use 1-4 amps if needed...
TN
Major Bass P...
Post Number: 427 Registered: Nov-06
Monday, December 04, 2006 - 06:23 GMT COOL, I believe I have traded around and picked up a 3XL 15D POWERBASS!!! Ithink its dual 1ohm so, will my Optidrive work? its .5 ohm stable? what will the dual 1 ohm sub need? 1 or .5 right? or not?
TN
Major Bass P...
Post Number: 428 Registered: Nov-06
Monday, December 04, 2006 - 06:30 GMT thats the sub
TN
Major Bass P...
Post Number: 429 Registered: Nov-06
Monday, December 04, 2006 - 06:37 GMT Box Specs 3XL-15D Optimum Ported Vol. Standard Metric Gross Vb Internal 5.0 cu. ft 141.58 Liters Circular Port 6" x 7.5" D 15.24cm x 19.05cm D Fb (Box Tuning) 40 Hz 40 Hz F3 (-3dB Cutoff) 33 Hz 33 Hz Pe (Watts-Rms) 250-500 Watts 250-500 Watts Subsonic Filter Setting If Applicable 35 Hz 35 Hz
