Username: Suliaman_p Toronto,
Ontario
Post Number: 1 Registered: Nov-06
Sunday, November 26, 2006 - 15:52 GMT wats the new codes for the cool.sat 5000 platinum
Username: Kamalrose Brampton,
Ontario
Post Number: 4 Registered: Nov-06
Wednesday, November 29, 2006 - 06:40 GMT need new keys for coolset 5000 platinum.
Username: Psychomofo Post Number: 11 Registered: Nov-06
Wednesday, November 29, 2006 - 06:48 GMT Cools@ is autorolling right now. I just flip the power switch in the back off then back on to speed up the process. Give it a shot.
Ontario
Post Number: 5 Registered: Nov-06
Wednesday, November 29, 2006 - 06:59 GMT that you psycho mofo i went to u.s.a. but when i came back my diah is not working i think i need new keys for coolset 5000
Username: Psychomofo Post Number: 15 Registered: Nov-06
Wednesday, November 29, 2006 - 07:15 GMT Sharon, make sure you are using bin 135 or 136 with the autoroll turned on, and autoroll will work. Cyberdss dot com has the new files as well as othe good fta sites.
