Username: Teamdeboy1971 OPTIDRIVE LN.,
TN
Major Bass P...
Post Number: 348 Registered: Nov-06
Friday, December 01, 2006 - 07:55 GMT I am hittin' 131.3 and don't have an alt. upgrade, I've allready went through 1 alt though, I have a lot of light dimming, hell people in front of me at night pull over they think I want bye!!lmao!!!!
Alabama
U.S.
Post Number: 10574 Registered: Jul-05
Friday, December 01, 2006 - 09:20 GMT I have read those meters are not very good when it comes to db readings...
Username: Logan__tille Post Number: 2892 Registered: Feb-06
Friday, December 01, 2006 - 11:13 GMT There supposed to be like 5-10dbs off.
Username: Bestmankind Fi AudioBTL
Post Number: 7534 Registered: Oct-05
Friday, December 01, 2006 - 15:08 GMT they may not be accurate as a tl but you can still use them. you can first meter your car with that and then when you change your box, meter again. at least you can see if you are improving or not.
Username: Alias747 Eclipse Ti,
MN
Post Number: 1685 Registered: Apr-05
Friday, December 01, 2006 - 15:17 GMT I don't know, Schoche also makes amp kits at walmart that have 12 GAUGE power wire..... My speaker wire is thicker than that....
Post Number: 7538 Registered: Oct-05
Friday, December 01, 2006 - 17:02 GMT spl meters and db meters are different. db measures sound while the spl meter measures sound pressure. i have a home theater db meter and i am only hitting in the high 120s while on a tl mic i am hitting 145.5
Username: Stnorris Davenport,
IA
US
Post Number: 1828 Registered: Apr-06
Friday, December 01, 2006 - 17:33 GMT spl meteres measure sound pressure level ...which is decibels. Sound pressure, sound level and dB. Sound is usually measured with microphones and they respond (approximately) proportionally to the sound pressure.
Post Number: 7545 Registered: Oct-05
Friday, December 01, 2006 - 18:26 GMT i guess i should of said a home theater meter and a spl meter.
Username: B101 DD, RE, FI, TREO, KICKERUSA
Post Number: 4018 Registered: Sep-05
Friday, December 01, 2006 - 20:32 GMT accurate? ha!! if u blow it in its packaging, you can make it do 130db!! its crap!! pure crap!!
