How to connect pansat 2700A to reciever
Username: Andrewmenia911
Post Number: 23
i have bought the null cable.. i want to know what i must do before i connect the reciever to the pc.. do i have to erase everything on the reciever first or not? also when i connect it to the pc.. should i plug it to the electric or not and also the switch on the back of the reciever should be on or off.. thanks
Username: Crazy_greek
Post Number: 222
The switch back of your receiver should be OFF.
when you ready to load your Bin to the receiver then turn the switch ON.
Username: 18_volts_baby
Super Moder...
Post Number: 159
I think this issue has been resovled.. He is now have trouble with scanning..
https://www.ecoustics.com/electronics/forum/home-video/299155.html
