Amp wire installation help
Username: Rickeyd87
Post Number: 121
I just ran 1/0 awg wire in my car and split it into two 4awg wires to run to my two amps. I have a 300 amp fuse on the 1/0 awg, should i put fuses on each 4awg wire too?
Username: Grebnereon
Post Number: 512
cant hurt anything.
Username: Andrew571
Post Number: 296
nah
Username: Redliner
Wilmington, Ma
Post Number: 3239
do u have a dist block cause that would b the correct way to do it
Username: Rickeyd87
Post Number: 122
Yea, i'm using a kicker distribution block. So I guess i shouldn't even put the extra fuses on there then. I might do it if I get bored one day.
Username: Sinful_systems70
Post Number: 110
Extra fuses will give you greater protection but sacrafice voltage to amps.
