Bronze Member Username: Trey4sportsPost Number: 83 Registered: Sep-06 | when your looking at purchasing a component speaker set and it says impedance: 4 ohms is that for the set of speakers or per speaker? |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 10446 Registered: Jul-05 | each speak is svc4ohms...so if u have a 2channel amp..that does 75rms x 2@4ohms...or 75rms per channel then u have a match |
