hey guys im new to the dish thing but i need help i have a pansat 2500 and i dont get any channels it dn can anybody pls help it was working before till bout a couple days ago i live in chicago if that matters
You need to change the keys in your box in order for it to work.Keys are not rolling anymore on DN.Look in the proper threads here,you will find the proper keys for your box and how to install them.Good advice,look it up,some people get mad about sppon feeding here.
tanx alot for the advise but like i said im new to this and i have no clue of what im doing but i apprciate the help but isnt that the whole point to be on here is to help each other out im just saying
Ok: it's been deleted but i'll try to guide u from memory.to change key's: press menu scroll down one to parenal control,then select sroll down to second pin,then enter 0000 scroll down to autoroll option,press select scroll down to dishnet ,puss left or right<> to turn autoroll off, then press exit scroll down to nagravision #2,press select scroll down one to oo in box,then sroll down again once to enter keys. after key's entered prees store [ok]button the store ''should flash a couple times. sroll back up to kay numbers and press> to set oo to o1 which is your second set of key's enter second set of key's then selest ok button,exit,exit, exit exit watch tv!
