noticed time zone was one hour off is there a way to correct it. or maybe the new bin does. If not how do i get in the program to change it thanks. pansat 3500
go to menu,then User Set Up,go down to Time Setting,on the first line it should say Time Zone,go one hour back from where it is.Then if the time under Current Time is not correct,click ok and make sure the day,month,year and time is correct.Then hit enter,exit exit exit until you are watching tv.This should fix it.
