people go download bin 288 for pansat2700 and 286t for 2500 and clones and all your problems will be solved, 288 works perfect, autorolls great, channel change speed is wicked... i would suggest you guys try it out. Bin 288 for pansat 2700 is found on all reputable dss sites i highly recommend this bin file, its great..
Some reputable DSS sites:
www.dssevolution dot com www.totalfta dot com www.dsscommunity dot com www.future-fta dot info
ENJOY
PS. And don't hesitate to post any openions you have about these bin files on this same thread.
it took about 25 secs on my receivers to autoroll the new keys, it went to 30% but its different for everyone it takes anywehre from 20 secs to (up to) an hour some times
I downloaded bin 288 and lost all my channels. I did a blind scan but could only get the channels back on echo7k. Echo 8 shows nothing with a blind scan. Anyone have an idea what to do? Thanks
Put ur coax cable directly into reciever while u blind scan ,then after scan,. reconnect it to your switch.A lso make shure your ant/lnb configure is set correctly in your set.
OK I got it!! The ant setting for echo 8.2 was changed when I downloaded bin 288. Perfect now and bin288 is rolling 100%. thanks for the help and I hope one day I can do the same for you guys. J
It is common for receiver antenna settings to change when uploading a new bin, ALWAYS recheck them, make any necessary corrections. and do a receiver reboot!
the One...I educated U again...here's another copy/paste for U!...LMAO ..I must have "educated" you here on at least on 1000 posts and left U these messages on at least 100 posts!....next he will write a book with my material, and put his name on it!
I am to good to write a book, I am a programmer and all the information you know about DSS, you have learned it from me anyways! its actually you who copies/pastes my posts from other sites. I hardly post on this site but ya i do see that you have spread my knowledge and experience to everyone here on this site.
