Narrowed it down to two tvs. Which one?
Username: 1lakerfan
Post Number: 46
Samsung LNS4095D or Sony Bravia KDL-40V2500
Username: Chitown
Post Number: 1316
Go with Samsung.
Username: Rysa3
Houston, Texas
Post Number: 40
I'm with Stof on this one.
Username: Minxie
Which Plasma HD/TV is the best-bet for the least problems in the 42-56 size range?
Username: Malooga
I've also narrowed it down to the 46" versions of these sets. Could either of you give some reasons for your preference for Samsung? Thanks.
Username: 1lakerfan
Post Number: 47
Actually I found another tv I might go with. Sony KDL-40XBR2. What do you think
Username: Tommyv
Rowlett, Texas
Post Number: 135
The XBR is better than any of the others mentioned. If you go with the XBR3 it has a 18 month or 2 year warranty. The samsung and sony models you mentioned before are both good but I prefer sony. In any event Im sure you will be happy with any of the sets you are looking at.
