Viewsat 11/26 Bin Working - just posted on totalfta*com
Username: Kriskros
Post Number: 81
www*totalfta*com
www*dsscentral*net
www*ftabins*net
Username: Labonitafda
Montreal, Quebec Canada
waht bin for viewsat 2000 platinum plz
Username: Danoh
Post Number: 35
I BELIEVE this is it DBPSW-061126P
Username: Psychomofo
Post Number: 13
You are correct Dan. Last letter of the file name P for platinum and last letter x for xtreme. DBPSW-061126P is the most current.
merci thanks
Username: Martinpraguer
Bohemia
Post Number: 8
Autoroll working.
By the way-previous DBPSW-061122X.PGM is working as well (no time to fiddle/updated it) - including Autoroll - when properly loaded (wait a minute before unplugging from computer), it only looses signal like once day - easy to correct with switch off/on. As for Autoroll it was off - put back to on - wait couple minutes and it's back in the business.
Cheerio
hi
how to turn my vs 2000 platinum autoroll off??
merci
Username: Abj
Post Number: 377
menu-option-highlight autoroll and press left or right arrow once should turn it off
