Hi, I am new in Canada.I have FTA satelitte receiver.and all programmes off since three days.I try to search buy didnt find. Please help me how i can change keys of my receiver or update keys to watch FTA signals. and how i can get update keys.I have receiver DVB DISK qb1.2.
That is not a VALID receiver what you are saying is like you have a reveiver called "DVD" look more closely if it does not say anything on the front other than the DVB sign and the Dicq 1.2 sign then you have a CLONE. Try to take a picture of your receiver an I will try to finf out what kind of reciever it is.
Thanks for your reply.On the left side of receiver is writen Music CoolTec and Right side DVB and Right Down Corner is write DISEqc1.2.I also uploading image.I realy apprciated your time to reply me.Thanks again
Thanks for all that support.I just check receiver again.The right side corner written is MultiStar Cool Tech.Plesae advise me how i can add file and which files i can use to watch programmes. Thanks again
I have Pantec MX Ultra: DVB-S.Please let me know how i can change keys or load files on receiver.and which files i need to use.Please guide as much as u can becoz i am not a good in this field.thanks very much
OK, this is the uploader that I use all the time and it has NEVER failed me (100%). PLEASE LOOK AT THE PICTURE INSIDE THE .ZIP FOLDER BEFORE YOU USE THE PROGRAM. THE PICTURE CONTAINS INSTRUCTIONS ON HOW TO USE THE PROGRAM.
unfortunitley not same error write failed(ERI).now i am thinking to buy any new receiver, I realy appreciated your detailes help.What you suggest for new receiver? Thanks again
