Building a box
Username: Goodie_goop
Midland, Texas U.S.
Post Number: 29
ok im building my first box this weekend and its nothing special just a single 10" probably sealed but i dont know exactly how many screws to get or what all i should have because i have seen different things on different sites so...also maybe somewhere i can get some exact measurements to make the box...
Username: Rovin
Trinidad & T...
Post Number: 9926
http://www.diysubwoofers.org/ .........
Username: Stnorris
Davenport, IA US
Post Number: 1764
what sub is it?
for a box you need mdf board (home depot or lowes), you need a box of wood screws, you need liquid nails, and you need caulk.
Midland, Texas U.S.
Post Number: 30
its just a crappy audiobahn sub i had lying around that im gunna use till i can afford a good quality system
but i guess just like a 1^ft sealed so i dont have to worry about making the port right...i shouldnt need calculations for that right? i mean just cut all sides 12"...?
Username: Stnorris
Davenport, IA US
Post Number: 1766
the board is .75 thick so no.
cut it like this:
(2) 13.5 x 13.5
(2) 12 x 13.5
(2) 12 x 12
Username: Rovin
Trinidad & T...
Post Number: 9927
Nope ! ^^^
u have 2 account 4 thickness of the wood so if u want 12" then its got 2 be 13.5" since 3/4" mdf is used
another note - i read a loooong time ago u should NEVER build a box with 2 equal sides (something called "standing waves")
ex : do Not use say 20 x 15 x 15 use maybe 20 x 14 x 16
http://www.the12volt.com/caraudio/boxcalcs.asp .....
Username: Rovin
Trinidad & T...
Post Number: 9928
i meant "nope !" to goodie not u steven ......
Username: Cashby
Post Number: 98
i like the way that sounds rovin ^^^ good thinking
Username: Stnorris
Davenport, IA US
Post Number: 1767
rovin my new box i just made had standing waves or w.e you want to call it calculated in. all boards were different. but i dont feel like drawing up a 1 cuft saeld box right now. those measurements up there should work fine though...
Username: Rovin
Trinidad & T...
Post Number: 9930
usually when i build boxes i try 2 design it so that 1 side is @ least a whole inch in width difference than the adjoining side
well in some cases u cant help but having 2 sides almost = but i try to get @ least 1 side 1/4" different 4 this reason ......
Midland, Texas U.S.
Post Number: 31
hmmm well i kinda drew up a sketch of how it would look with measurements and i think i can do it with the:
(2) 13.5 x 13.5
(2) 12 x 13.5
(2) 12 x 12
but im not sure how i could make the sides unequal...? never really done much with building this kind of stuff
Username: Rovin
Trinidad & T...
Post Number: 9933
thats not correct
try this then
15 wide x 14 tall x 12.5 deep using 0.75" mdf
enter it here http://www.the12volt.com/caraudio/boxcalcs.asp
note u will get 1.07 - the .07 extra is for sub displacement ......
Midland, Texas U.S.
Post Number: 32
sweet, thanks...ill make an attempt at it tomoro and if somethin doesnt turn out right....then i guess i will b back lol
