New member Username: Big_reazonPost Number: 1 Registered: Nov-06 | lol. Now hear is what I have its at 1986 monte carlo ls. I got my mids and highs extremely loud to prep up for this point. Now I can afford to get some bass. I had 4 w6 12s in my car powered up by two huge pheonix gold amps. That system beat hard to have been done in 1998. But now its 2006 I've heard some systems that would put my old system to sleep. Two 13w7s put my system away. Now I need something that will blow that rear window out but at low levels will sound good/ decent. I dont want subs that need 6000 watts a piece. I want the subs to be 12s. I thinks I got about 9 to 10 cubic feet for 4 subs. All seperate boxes fit my car correctly. I looked at some stereo integrity mags are the some heart pounding subs? I want that bass that hurts. By budget on subs is about 2 grand just subs. What should I get if I want that super hard hitting bass. I need each sub to hit harder than a w7. And cant require more than 2.5 subic feet. Could even do leess subs. I just want something that breaks backs. [IMG]http://i85.photobucket.com/albums/k53/Bigreazon/Picture46010.jpg[/IMG] This is what I wnat to beat this and 4 13w7 is that possible in my space confinement. Whts is the max amount of bass I can gett with that kind of area and sound good at lower levels. |
Gold Member Username: 54danny54KY More Wang Th... Post Number: 2946 Registered: Nov-04 | get 4 fully loaded BTL 12's give em at least 2k watts a piece...but considering the price for subs, amps, and elec upgrades to run that beast, its almost unreal. plus it wont fit in a monte carlo now...u might be able to fit 2 btl 12's and fiberglass the back to get as much cubic feet as you can then give em 1500-2000 watts each and buy urself a HO alt, then you will be fine. |
Gold Member Username: BestmankindFi AudioBTL Post Number: 7327 Registered: Oct-05 | my 2 btl 15s fully loaded put 2 12w7s to sleep and then some. |
Gold Member Username: DelsolePost Number: 1008 Registered: Feb-05 | http://www.reaudio.com/specs.html#sp_xxx you could try some of them |
Gold Member Username: DelsolePost Number: 1009 Registered: Feb-05 | some DD's would sute you good |
Silver Member Username: Livin_loudPost Number: 535 Registered: Jan-06 | You'd be better off with 2 15's. It would save you money and give them plenty of space. ^^^DD does sound like a good choice. 2 9515's with around 2500wrms each would devastate... |
Silver Member Username: Livin_loudPost Number: 536 Registered: Jan-06 | http://cgi.ebay.com/DIGITAL-DESIGNS-9918-MONSTER-SUBWOOFER-DD-AUDIO-SUB-18_W0QQi temZ260054579814QQihZ016QQcategoryZ18805QQssPageNameZWDVWQQrdZ1QQcmdZViewItem or just get this and make everybody in the forum jealous and have no competition whatsoever in SPL |
Gold Member Username: DelsolePost Number: 1015 Registered: Feb-05 | i was lookin at the exact sub when i suggested DD. that things a monster |
Silver Member Username: Denali_on_22sMaryville, TN Us Post Number: 488 Registered: Feb-06 | Well, you're talking about beating out probably 4000+ RMS by getting louder than the 4 W7s and Solobarics, so it may take 6000 watts to accomplish your goal. Anyways, fromt he looks of thing it seems as if you dont have any money limitations. You could look into a couple Treo SSX or a couple RE MX's too. The MX 15s are good in 2 cubic feet, so they would be ideal for what your looking for. Get a couple of those with 2000-2500 watts each. Thats if you want to go the expensive route. If not, then go with the DD 18. That's a BADASS sub! I'm shaking thinking about it. |
Gold Member Username: RovinTrinidad & T... Post Number: 9932 Registered: Jul-05 | damn that DD9918 is a killer ! u will need a killer amp/s to power that baby up ...... |
Gold Member Username: Troy81Tavernier, Fl Us Post Number: 1377 Registered: Mar-06 | 4 ssx 12s, 4 dd9912's |
Silver Member Username: Teamdeboy1971OPTIDRIVE LN., TN Major Bass P... Post Number: 236 Registered: Nov-06 | Oh man, have I got an encloser 4-u!!!! I have an encloser that was made for a new Impala! The guy bolted in his 4-12inch square SoloX's and didn't like the subs, so I ended up with this Brand new just built Nice sub box!! I will put some pics of it on here the day after Turkey day!! I believe if you wanted to go with square subs, you box is done! The guy that built it at Extreme Car Audio in Knoxville, Tn. told me that it wouldn't be hardly any trouble to modify from square to round!! So look at the pics when I post them, they have a good name in box building, thier ports are unique!!! a must see!! People can get a hold of me faster at aprillongmire@yahoo.com |
Gold Member Username: Crayola0Wisconsin Post Number: 1486 Registered: Jun-06 | Go with a couple of Jugs! |
Gold Member Username: Extrmndor3Friday, Str8t to the Gentlemans club Post Number: 2681 Registered: Feb-06 | get 2 apxx 18 inch and get four 5.1 atomic amps get dual 300+alternator dual brackets and 4 runs of 0 gauge kolosus cable 2 for- and 2 for+ |
Gold Member Username: Extrmndor3Friday, Str8t to the Gentlemans club Post Number: 2682 Registered: Feb-06 | oh u want 12's?? get 2 12's apxx |
Gold Member Username: Extrmndor3Friday, Str8t to the Gentlemans club Post Number: 2683 Registered: Feb-06 | if u want get 4 apxx but it will be too much for ya and too much for the jl's w7 |
Silver Member Username: RvlacosDD 3512 United States Post Number: 845 Registered: Sep-06 | 2 9912's or 2 9512's man if you could power them they would do some damage! |
Gold Member Username: Basshead86SubBassMidBass Post Number: 8970 Registered: Aug-05 | install install install if 2 13W7's put your 4 W6's to sleep. you had a bad install. 4 12's should be louder than 2 15's all day....... i say yoou get 2 Audioque 15" HD3's and 2 massive audio P3000.1's(or any amps in the 3000wRMS likeness) and be done. HO alt. several runs of 1/0 gauge wire. Battery bank. |
Silver Member Username: JohammbassIRL Post Number: 693 Registered: May-06 | Muddy is right about the 4 W6's. Cone area rulzz. If you powered them right and installed them right there is now way that two W7's would be louder |
