Sigh thought I had my system all figured out until my friend decided to put his RF T20001BD up for sale for around $500..
Number of Channels 1 Rated Power 750 W x 1 @ 4 Ohms 1500 W x 1 @ 2 Ohms 2000 W x 1 @ 1 Ohm Total Power 2000 Watts Bridgeable Yes (bd-sync2 cable required) MasterSync PowerSync Crossover Controls Low-Pass (LP): 32-250Hz 24db/octave Butterworth Infrasonic filter: 27Hz 12db/octave Tone Controls Bass: 0dB to +18dB @ 35-70Hz Phase: 0/180 degrees Signal Input Low level: 1 RCA pair Signal Output Low level: 1 RCA pair Power Input Connector Block Power Wire Gauge 1/0 AWG Speaker Output Connector Screw terminal barrier strip Speaker Wire Gauge 8 AWG to 18 AWG Heat Sink Type Cast aluminum Cooling Fan cooled Remote Controls ParaPunch Bass EQ (included with cable) Visual Indicators Power On Thermal Status Speaker Protection Circuit Topology Class Class bd Frequency Response 20Hz to 300Hz +/- 0.5 dB Dimensions 2.6 x 12.8 x 23 (in) 6.6 x 32.5 x 58.4 (cm) Shipping Weight 28 Lbs. (12.7 Kg.)
Do you guys think this a good amp? and if it is what 1 12 or 2 12's would you use with it? I have about 4 cu ft in my trunk to work with. I lean a little towards SQ more than SPL but both are important and SQL subs are more than welcome :p
does he have enough room for 2 15's???????? I dont know bout that unless u seal em and even then it seems kinda small for 2 15's.............Id say go with a Q or an HD3
my budget for the subs is $1000, not sure if thats too cheap but I can go higher if need be. It also does scare me that I was planning on putting 2 Qs or 2 HD3s but you guys are saying just 1....any particular reason for that?
Well no offense, but that amp isnt the best for SQ systems lol. It's a lil powerful, but either way you can get 2 S.I. Mags or 2 12" Q's, don't know why they're telling you just one, I would def do the 2 12"s if you can fit them, you get that extra bit of SPL. PSSST, if you dont need an amp that big I'll take it off your hands, I can trade you an amp and some cash for it.
i would say get 2 12" mag's they would work perfect with that amp. also the mags sound very good and at the sametime can get very loud also what did u know theres a group sale going on lol
Well the reason that I see for the 1 sub setup is you said you only had 4cu.ft. that would be hard to do if you were doing 2-12"Mags you would probably want 5-6cubes !!
