Thanks for replying Jason. What's the procedure to doing this? I have a Pansat 2500 clone, Dish Network already set up with 110, 119, and 61.5. What would be my cheapest method to adding Globecast? When you said "true" Free to Air does this, what do you mean exactly?
Ranjeet, Hi, this is off the subject, but you might be able to help. Yesterday, I bought co*lsat from a friend who has only 119 set. I have 119, 110 and 61.5 similar to your setting. Can you tell me how do you have yours setup? I know you have different receiver, but the principle might be the same. I also have Globecast and wondering how to add that dish to the others. Thanks for your reply.
- 110/119 can be on one dish - 61.5 must be on another dish - What globecast do you have? - How many dishes do you have? - You will need 1-LNB for every SAT - If SATs more than 25 degrees apart you must have a seperate dish
Thanks King Tape, * 110/119 are on one dish * 61.5 is on a seperate dish * Telstar 5KU 30" dish FTA * Total of 3 (2 Dish Network, dish 500 and reqular) and 30" dish * I have 1 LNP for one Sat Telstar 5KU
I'm not sure what switch they are using with DN (meaning to combine the DN 500 and the regualr), not sure how to hookup the Telstar 5 with DN with the co*lsat 5000. hope that enough info. Sam
