Bronze Member Username: ShwayPost Number: 18 Registered: Aug-05 | So I ordered a type R, and I was wondering, I read somewhere that some subs need to be broken in. So I was curious if I do need to break it in, and if so for how long? Also, I am a little confused by some of the diagrams to wire the sub to the amp. Does anyone have any source to a more detailed diagram, or better yet some pics??? Thanks for any help. I am a noob or w/e. |
Silver Member Username: Nyyfan13VA USA Post Number: 895 Registered: Jul-06 | the12volt.com car audio sub wiring shuold give enough info for you |
Gold Member Username: Logan__tilleNothing Right Now, Www.Audioque... United States Post Number: 2578 Registered: Feb-06 | Thats just a myth, I say just run it. |
Bronze Member Username: ShwayPost Number: 19 Registered: Aug-05 | http://www.the12volt.com/images4/woofer_wiring/cropped/1_2ohm_dvc_1ohm.gif Ok, so I know the amp has 2 Posatives and 2 negatives, acording to this diagram, am I just runing the neg. wire to one neg on the amp, and one pos. wire to one pos. on the amp? Thanks |
Silver Member Username: RvlacosDD 3512 United States Post Number: 824 Registered: Sep-06 | some subs do need to be broke in! if it doesnt what could it hurt to keep it down for a couple hours? |
Gold Member Username: StnorrisDavenport, IA US Post Number: 1715 Registered: Apr-06 | i posted on the other type r thread...didnt know there was 2...woops... |
Silver Member Username: Andrew571Stillwater/Edmond, Oklahoma USA Post Number: 265 Registered: Oct-05 | ...waits for rovin to post.... |
Gold Member Username: Troy81Tavernier, Fl Us Post Number: 1373 Registered: Mar-06 | what kind of amp is it? |
Bronze Member Username: PaogrAthensGreece Post Number: 57 Registered: Dec-05 | Troy Stafford did you want to write this: "whatkindofampisit?" instead of this: "ucaoeéiaioaiéoéo?" |
Gold Member Username: RovinTrinidad & T... Post Number: 9896 Registered: Jul-05 | "...waits for rovin to post...." lol - i guess i'm Mr. Type R then u can play them @ like 1/2 rec power 4 about 2 wks daily couple hrs per day - should get naturally broken by then but if u dont listen 2 them with as much hrs then obviously they will take longer ...} |
