New member Username: Jay2004Post Number: 2 Registered: Nov-06 | the constant back and fourth struggle with my autoroll the last two days has me quite frustrated, so i was able to get the bin about 20 minutes ago, pop in the usb update the file, and now the receiver turned off and i guess turned back on showing just one small dash in the middle window... tried to turn off from the back and turn it back on it went right back to one dash and nothing else... anyone else experiencing this ???? help is greatly appreciated... |
Silver Member Username: Minn_rockPost Number: 802 Registered: Aug-06 | Justin try to load back the bin u had before..than load the new bin again.. |
New member Username: Jay2004Post Number: 3 Registered: Nov-06 | it wont even let me access any menus or anything, turn off and then back on, a black screen, and one dash in the window... |
Bronze Member Username: X302Longlac, Ontario Canada Post Number: 32 Registered: Jun-06 | don't worry about accessing menus right now...try loading previous bin you were using then new bin again...if the problem persists, load the factory bin and then new bin...good luck-----X FYI- loaded the new bin in all 3 of my plat. and all rolled in under 2 minutes |
Silver Member Username: BirdwatcherPost Number: 503 Registered: Jul-06 | its fried!!!! |
New member Username: Jay2004Post Number: 4 Registered: Nov-06 | how do i load the old bin if i cant see anything??? just put the usb stick in and...??? |
Silver Member Username: GrimreeperPost Number: 254 Registered: Feb-06 | usb stick?????? vs2000 doesnt have a usb slot tell us a little more |
Gold Member Username: LklivesPost Number: 5786 Registered: Jan-06 | Jay...I think U need to read and learn all about your receiver..U have a simple problem with a simle fix..which has already been given U here..unless there's info U have NOT provided.. |
Bronze Member Username: Dave_singhPost Number: 51 Registered: Jun-06 | can some one give me the loder for viewsat please att for me please |
Silver Member Username: Donnie1973Tennessee Post Number: 489 Registered: May-06 | hes talking about the usb to serial adapter i bet.open your loader, put the bin file in, and do it! |
Bronze Member Username: Dave_singhPost Number: 52 Registered: Jun-06 | i need the loader |
Silver Member Username: Hawaiian_timeHawaii Post Number: 727 Registered: Apr-06 | He could have the viewsat ultra and loaded the wrong bin. |
Silver Member Username: Hawaiian_timeHawaii Post Number: 728 Registered: Apr-06 | Jay, did you load the PFTAUSW-061121U bin? That is the one you need. |
Silver Member Username: Hawaiian_timeHawaii Post Number: 729 Registered: Apr-06 | Try loading the VSULTRA_v117_factory_bin first, then the new one. |
Silver Member Username: Hawaiian_timeHawaii Post Number: 730 Registered: Apr-06 | Get the bins at totalfta.c@m. Register first. |
Silver Member Username: Hawaiian_timeHawaii Post Number: 731 Registered: Apr-06 | Use your data cable to load bins. |
New member Username: Jay2004Post Number: 5 Registered: Nov-06 | ITS OFFICIAL ITS FRIED!!! I HAVE TO NOW SEND IT BACK TO VIEWSAT.... thank you all for trying to help anyway... |
