What amp for a type R
Username: Shway
Post Number: 11
Ok, I am going to be ordering a alpine type R soon, and I don't know what amp to get. I know they make two diff. type R's, the dual 2 ohm and 4 ohm. So what do you guys think??? (It's just one sub) What amp powers the type R best for the money? Thanks!!!
Username: Livin_loud
Post Number: 474
It depends. Do you want to upgrade in the future?
Username: Rovin
Trinidad & T...
Post Number: 9865
if u order the 1222 model make sure ur amp is a true 600wrms @ 1ohm model
if u order the 1242 model make sure ur amp is a true 600wrms @ 2ohm model...
Username: Shway
Post Number: 12
no need to upgrade, I feel that that will be enough power for me.
Post Number: 475
Well then Rovin has the right idea. I'd personally go with the 2ohm sub...
Username: Shway
Post Number: 13
Alright, on response to the previous post, If I go wit the 2 ohm sub, how would this amp perform? http://sonicelectronix.com/item_6521.html
I have heard things about hifonics amps. Thanks for the help!!!
Post Number: 477
Those are overrated a little bit, but they are decent amps
This would work pretty good
http://sonicelectronix.com/item_2748.html
Post Number: 478
Also, if you're willing, buy off of eBay. You'll get the best deals there
Username: Shway
Post Number: 14
Alright, yah I was thinkin bout that. Do you know of any reliable companys on there?
Post Number: 480
Just go by the feedback. I usually only buy if a person has 98% or more, and has a decent amount, say over 100
Username: Udai
Post Number: 215
I read about people giving their R's over 800wrms all day long without a problem (also a good amount running over 1kwrms). Check out the caraudio.com forum-type r thread.
Username: Udai
Post Number: 216
- I forgot to add.. this is all on a ported setup, not sealed.
Username: Rovin
Trinidad & T...
Post Number: 9871
that PG amp Eric pointed out is a good choice in that it puts out no matter what ohms ur sub is .....
