Co*lsat help
Username: Muer_killa0258
Post Number: 9
what keys do i use for co*lsat? i keep seeyin pansat and viewsat but no co*olsat. help plz
Post Number: 10
i have co*lsat 5000 plat.
Username: Minn_rock
Post Number: 797
RO RO..THERE R ONLY 1 SETS OF KEYS, THEY WORK FOR KIND OF RECEIVERS..
DN
Key01: 93 C2 59 35 EE 4E 0B 81 1B EB CA F7 0E 78 E4 06 (Active)
Post Number: 11
thanks minn rock but i have another problem, i dont kno exactly how to input da keys into co*lsat. i am in the menu but i am seeing more numbers than i should. can u shed some light on dis?
Username: Tekomi_elhoyo
Post Number: 30
enter 8282 like looking for a channel.
Post Number: 12
guys the problem is, the slot as to where i enter the keys, they only have space for 8 sets of numbers while the full keys are 16 sets. any help PLZ???
Username: Miguel03
Tucson
Post Number: 93
OK, ROR
1. make sure you have current bin, press 8282 on any channel
2. you should see key edit
3. on slot 1 label Nagravision, press down arrow till you are on the first row of keys.The reason people list 16keys is because you take the first 8keys or half of the keys from the 16 they gave you and insert them in 10 and 11 or 20, 21, depending on the ones that change.
For example you might see:Key 00
00:5D 95 EB F6 06 08 43 B2 25 33 DA 77 DC 51 EF E4
or
86:5D 95 EB F6 06 08 43 B2 25 33 DA 77 DC 51 EF E4
This is key 00:
you want to insert half of the 16 keys in slot 10 and 11.
For example:
10:5D 95 EB F6 06 08 43 B2
11:25 33 DA 77 DC 51 EF E4
This is: Key 01
01:56 41 70 E1 21 6F 61 F7 5B 2B 19 97 86 EA F0 0E
or
96:56 41 70 E1 21 6F 61 F7 5B 2B 19 97 86 EA F0 0E
You want to insert half of the 16 keys in slot 20 and 21:
For example:
20:56 41 70 E1 21 6F 61 F7
21:5B 2B 19 97 86 EA F0 0E
Same thing for Bev, but you insert keys in Nag 2.
