How is this box for the Type R???
Username: Shway
Post Number: 15
So I will be getting one type R, and I would like decent sound quality, with a little more spl(Or w/e). So how would this box do? http://www.sonicelectronix.com/item_7521.html#
if you guys know of any other good boxes please post. I was going to make my own, but I think it will ultimately be cheaper to just buy a premade.
Username: Tjmutlow
Post Number: 3216
make sure you get a box with the right specs for sub, that box is 2.9cft before ports and sub displcements.
Username: Tjmutlow
Post Number: 3219
looks like net internal volume for vented box is 1.3cft
Username: Rovin
Trinidad & T...
Post Number: 9870
vol without displacements if built with 5/8" mdf = 3.04cuft
vol without displacements if built with 3/4" mdf = 2.90cuft
http://www.the12volt.com/caraudio/boxcalcs.asp
if its 3/4 mdf it sould work ok - i hope its low tuned though cause type Rs love low freq tuned boxes .......
