I have 2 JL W7 subs and wonder which one of these amps will push it? The JL 1000/1 or the Arc Audio 1000 watt amp I think its the KAR series. I can get the Arc audio about $100 cheaper. Also is the JL 1000/1 amp perfectly match for 2 10W7s and how loud is that setup in db ratings, does anyone know?
Yes the 1000/1 is meant to power 2 10W7s. And there are WAY too many factors that go into your installation that can determine how many dbs you can hit. No way can anyone even start to guess.
