L5'S TYPE-R'S OR MTX 9500'S
Username: Lilmanshakur7196
SO I JUS GOT PAID AND IM UPGRADING MY SUBS ... WOULD IT BE A BETTER BUY TO GET 2 12"KICKER L5'S, 2 12"ALPINE TYPE-R'S, OR 2 12" MTX 9500'S
Username: 54danny54
Betsy layne, Kentucky..GO... \blink, red,...
Post Number: 2886
type R
Username: Rick_ross
Post Number: 630
type r's
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 3391
those 9500s can get pretty loud... why is that you only options?
SO FOR THE TYPE R'S WOULD IT B BETTER TO USE THEM WITH A AUDIOBAHN A8000V OR A JBL GTO 1201
Username: Logan__tille
Www.Audioque.comUSA
Post Number: 2442
2 Audio SD2.5s
Www.Audioque.comUSA
Post Number: 2443
audioque***
TREVOR WELL I HAVE 2 6X9 AND 2 61/2 ALPINE COAXIAL SPEAKERS SO I WAS WANTING TO GO WITH TYPE RS JUS TO STAY ALL ALPINE BUT I LIKE HOW THE 9500 AND THE L5'S POUND
Username: Dustin3
Tigard, OR U.S.
Post Number: 4145
look into some FI Q's or even one FI Q will dom on those.. :-) www.ficaraudio.com
Post Number: 3398
It's just about never good to stay with the whole company throughout everything. better can be had using different companies for different parts of your system. the 9500s are power hungry. so far i like logans suggestion. or maybe go for something else like the massive CW12 or AA arsenals or Fi ssd or theres lots of great subs out there. look around :-)
Username: Basshead86
OG eCoustics Member
Post Number: 8624
too bad DLS doesn't make HU's....:-):-):-)
Username: Stnorris
Davenport, IA US
Post Number: 1595
haha those 9500s will smoke the rs. most of the time in two pretty good installs, 1 12 9500 will beat 2 rs. i seen it done. but 2 12 9500s will definantly beat them. i dont think either of them are impressive or anything in sq so...
steve what amp would i get to go wit those 9500 would work best
Username: Redliner
Wilmington, Ma
Post Number: 2906
sqtype r's will win but spl the 9500's will win but u need to make sure u have the charging system for the 9500
Username: Cashby
Post Number: 67
the 9500 (one of them) will hit harder then 2 type R's they'll will def. kill them. i have one for sale also if ur intrested......but dont get me wrong i used to have to Type R's and they are excellent subs for the price is the sound quality is better then the 9500
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 10121
all 3 of the subs sux... and are not worth the money...anybody wanna say otherwise???
Username: Cashby
Post Number: 68
ya id like too...i mean if ur not looking to spend a whole lot there is nothing wrong with the Type R...ya its no Fi BTL, HD3, or DD9515 but there a good sounding sub with good quality.
Username: Bernymac
AQ HD3!!, CA United States
Post Number: 925
richard, best thing to do is save that money, take some time, and look around. You don't want to rush into something that you'll get tired of later down the road. Ask around with what other options there are with your budget. To get a subwoofer that handles 1000rms and you want to feed it 1000rms, your going to spend a good amount of $ on amps and if you plan to double that since it seems like you want 2 subwoofers, then your going to have to consider upgrading your charging system. So best advice, stay around, read, learn, ask around some more, and then decide once your confident.
HD3, Www.Audioque... United States
Post Number: 2543
http://rover.ebay.com/rover/1/711-53200-19255-0/1?ff3=4&pub=5574831155&toolid=10001&campid=5336746880&customid=&mpre=http%3A//cgi.ebay.com/ws/eBayISAPI .dll%3FViewItem%26item%3D290052314439&ru=http://search.ebay.com:80/290052314439_ W0QQfkrZ1QQfromZR8QQfviZ1
