if you already got the amp then i guess your stuck. that amp looks like it puts out the most power brided mono at 1ohm so get the 2ohm sub and wire to one ohm
ya thats wat i was gonna do...i figured it was a a little overated but then i looked down at the 4400 watts RMS x 1 @ 1 ohm and i was jus gonna run it all at 1 ohm to the BTL....? do u think this will sound good mat??
yes i plan on getting a irragi 300 amp HO alt. and i already have all the 0 ga wire..i have the big 3 done in 0 ga. wire also..and i plan to get a couple yellowtops or some kinetiks.
do u have any other suggestions on wat i need if i get the amp...i have a 5 farad PA cap. from my last system but i dont think im going to use it...they seem kinda worthless...but tell me otherwise if im wrong
How much do those orions run?? prolly more then wat i payed for the MA....? i mean honestly wats so wrong with the MA...its came with a 2 year warranty and even if it is a little overrated wats that put it at maybe 3500 WRMS + ??? i got it for $399.99
richard im a newb...but if i were looking in the specs for the amp and i saw the signal to noise ratio or w/e or the sensitivity is that how u can tell if the signal will be clean or not??
