Subwoofer noise
Username: Volfenhagking1600
VolFenHag
Post Number: 181
When i have my volume all the way down to zero...my subs still rumble a little bit. What is the problem
Username: Andrew571
Post Number: 233
recheck grounds
dont run ur RCA along the same side of your car as the power wire
VolFenHag
Post Number: 193
only the right channel does it tho...and i didnt run the power on the same side as rca's btw
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 526
Ive actually found that power beside doesnt make a difference
Rock Vegas, NC US
Post Number: 527
beside RCA's***
Username: Adddisorder
West palm, Florida
Post Number: 1918
yup your right andrew only if they are really crappy rcas it might pick up slight noise
Username: Dustin3
Tigard, OR U.S.
Post Number: 4171
and i dont think that it would be a rumbling noise.. usually some kind of alternator whine with the ones that i have heard..
re-chec your ground, and maybe check your ground behind the HU..
did this just start hapening?
VolFenHag
Post Number: 194
actually i hooked the subs up and they worked fine...then i went inside my house to eat and came back out to mess with them again and the right channel started rumbling
VolFenHag
Post Number: 195
i dont think it would be the ground though because only the right channel does it??IDK
Username: Wolfman1966
WEST MONROE , LOUISIANA USA
Post Number: 1123
main problem is Volf's...lol, check rca's
Username: Andrew571
Post Number: 234
make sure the speaker input terminals dont have like a random thread of wire touching somethings its not, i usually recut the wire so its a clean connection
VolFenHag
Post Number: 196
its only the right channel and i tried all the diff. combinationss for the rca's and it still rumbles
Username: Dustin3
Tigard, OR U.S.
Post Number: 4177
well, youre right channel is prolly screwed up, i dont know if you did anything to it or not. what kind of amp is tihs?
VolFenHag
Post Number: 197
its a volfenhag amp 800wrms/2400peak http://cardiscountstereos.com/catalog%20page.asp?Product+%23=ZX7190 this is it
