Dual 1 or Dual 2 ohm????
Username: Cashby
Post Number: 72
I just bought the HK802Sk amp from MA audio and here are the specs on the amp:
500 watts RMS x 2 @ 4 Ohms Stereo
800 watt RMS x 2 @ 2 Ohms Stereo
1,400 watt RMS x 2 @ 1 Ohm Stereo
2,200 watts RMS x 2 @ 0.5 Ohm Stereo
4,400 watt RMS x 1 @ 1 Ohm Bridged mono
Now i am wondering if i should get the Dual 1 or Dual 2 Ohm Sub...It's going to be a BTL 15" ???
Username: Adddisorder
West palm, Florida
Post Number: 1908
those specs look horribly overrated!
if you already got the amp then i guess your stuck. that amp looks like it puts out the most power brided mono at 1ohm so get the 2ohm sub and wire to one ohm
Username: Cashby
Post Number: 73
ya thats wat i was gonna do...i figured it was a a little overated but then i looked down at the 4400 watts RMS x 1 @ 1 ohm and i was jus gonna run it all at 1 ohm to the BTL....? do u think this will sound good mat??
West palm, Florida
Post Number: 1911
im not to familiure with that amp so i have no idea what power it really puts out.
but if your definatly going to use that amp your going to have to wire it to 1ohm with a D2 BTL
if that amp puts out even close to that amount of power your going to need a good charging system like and HO alt and batteries. and lots of 1/0g wire
Username: Cashby
Post Number: 74
yes i plan on getting a irragi 300 amp HO alt. and i already have all the 0 ga wire..i have the big 3 done in 0 ga. wire also..and i plan to get a couple yellowtops or some kinetiks.
Username: Cashby
Post Number: 75
do u have any other suggestions on wat i need if i get the amp...i have a 5 farad PA cap. from my last system but i dont think im going to use it...they seem kinda worthless...but tell me otherwise if im wrong
West palm, Florida
Post Number: 1914
oh dude if you didnt get the amp dont. and dont use the cap.
sounds like your trying to put together a nice system so dont blow it with that amp.
look into a orion 2500d and wire it to .5ohm(2800-3000rms)
or a memphis 4k
and ask some other people for a good amp like that
Username: B101
DD, RE, FI, TREO, KICKERUSA
Post Number: 3934
what mat dope said...
Username: Cashby
Post Number: 76
How much do those orions run?? prolly more then wat i payed for the MA....? i mean honestly wats so wrong with the MA...its came with a 2 year warranty and even if it is a little overrated wats that put it at maybe 3500 WRMS + ??? i got it for $399.99
Username: Rvlacos
DD 3512 United States
Post Number: 473
maybe 3000wrms but even at that price= decent but what about how clean the signal is? ya get what ya pay for
Username: Cashby
Post Number: 79
richard im a newb...but if i were looking in the specs for the amp and i saw the signal to noise ratio or w/e or the sensitivity is that how u can tell if the signal will be clean or not??
