New member Username: MikedabehmPost Number: 1 Registered: Nov-06 | just bought LG hd dvd RC199H I have The Samsung Dlp,Kenwood digital dts receiver,and have comcast hd cable. Now i cant figure out the best way to hook all this stuff up any ideas. thanks Mike |
Silver Member Username: MccambleyBREEZY POINT, NY USA Post Number: 296 Registered: Jun-05 | Try here, I stole this from Berni http://www.ceaconnectionsguide.com/ |
New member Username: MikedabehmPost Number: 2 Registered: Nov-06 | Thanks Casey, This realy helps, but i have a couple more questions. Is a setup box the same as a cable box, and why do you go in and out both ways between the dvr and the Av receiver? thanks again . |
Platinum Member Username: Project6Post Number: 11482 Registered: Dec-03 | I can't take credit for that link, Casey Another member posted that from way back. |
Silver Member Username: MccambleyBREEZY POINT, NY USA Post Number: 299 Registered: Jun-05 | Mike yes on the settop box and cable box. The DVR I don't know, but to guess all recording devices (tape decks,VCR) go in the receiver and out. |
New member Username: MikedabehmPost Number: 3 Registered: Nov-06 | Thanks Casey the problem with that site it does not show all componets hooked together at once. thanks again Mike |
