New bin 1.28 for cw600p lots of new&old feutures
Username: Brucester
Post Number: 102
C/P Copy
New release V1.28 for Captiveworks CW-600S PREMIUM. It includes the
following:
-improved the speed of changing channels (you will notice the
differnce when you go from one channel to the other)
-fixed the problem for showing scramble channels that appeared
sometimes when switching channels.
-fixed problem of rebooting in real PIP which it happened if you moved
the small window to the top left corner.
-while in EPG now you can enter a channel number and the epg will jump
to that channe.
-while in EPG and you press green button and you set timer for a
certain show, the guide for that show will be highlighted.
DONT FORGET SOME OF THE GREAT OLD FEATURES THAT YOU CAN USE ON THE
PREMIUM BOX SUCH AS THE FOLLOWING:
-Configiring your local cities so you can watch your local channels
with the same numbers as it prodcasts localy
to do so: Menu->accessories->Config City->choose your state and city.
to view list of your local channels press SAT->local channels.
-Save multiple channel lists in the box and load whichever you like
to do so: Menu->System Setting->User Channel List->Save/Load
-Load Icon files to have the logos for dish/bev channels each time you
change channel or to display it in the EPG.
to do so: you need to find the lcon file which was released earlier
this year and then go Menu->system Setting->OSD->Display Icon YES, also
EPG style NEW.
-Get all the channels with Full name (for example it will display "THE
WEATHER CAHNNEL" instead of "TWC")
to do so: You will need to load the full name file that was released
earlier this year and then go to MENU->SYSTEM
SETTING->SYSTEM->Bell&dishnet Full Name turn it to "ON"
-Leave the channel on specific number for 10 minutes to get the 7day
EPG loaded.
There are so many other features that was implemented in the past year
and you can find it easily by browsing the menu and many more new
features are coming out soon. Get the most out of your box and use these
features.
Username: Coolsat7000
You can dowload it here
http://cyberdss.com/index.php?referrerid=2
