shabab i am not to sure about the classic but you can check under the parental control section in the options menu you will have to go to second pin and put in 0000 or w/e pin u used and that should do that trick good luck
You can not turn off the autoroll in classic NA. It is built in the bin. You can only put the bin in manually and hope for the best. With the new ECM in stream, you have to tinker more with the classic NA every time a new keycode comes. good luck and happy testing with it.
hello can someone tell me what is channel listing i have pansat 2500a 110 is all i can get .i need weather, lifetime, channel them ..they say ineed 119 .cant get 119 only 110 tell me if i can get these channel in on 110. what ineed to do, or direct me to a site that would help me.i need help pleeese be patient im new at this.
