Loosing channels , Any one else
Username: Charjam
Post Number: 90
i was loosing channels so i deleted everything and did a blind scan and lost the western channel [ewstrn] [ AMC ] [ COURT ] and some others Fox news Is any one else having this problem????????????
Username: Satscanner
NDS Laboratory
Post Number: 51
Mine working fine. Do u have tp autoupdate on ? Were u getting "srambled or bad channel" then reset box by rear ower switch.But they should show up on blind scan even if moved to new tp's. The listings /channels used to disappear on some old bins that I ran. Make shure u have lastest bin. Other than need more info on ur set up and ird thats about all think of.Make shure u have good signal/dish aimed properly or u can loose tp's. Could be weather related also?
Username: Charjam
Post Number: 91
Yea i think it is the weather , I will wait for it to clear up then i will do it again , I have a 2700a and 282 file but it has been working fine the keys has been rolling fine i haven't had to change the keys in a long time . Thanks for the reply
Username: Nlempb
i started losing channels to....but only one 1 sat.,and the signal is good. it keeps saying bad channel, then does channel update, then i lose half of my chan., its on sat 119w or echo 8.6. its on the 2500a pansat nag2. wtf is up? anyone got a clue?? thanks me
Username: Lacey_jane
Ont Canada
Post Number: 36
yeah I have lost alot of channels too, deleted and blind scanned too, tp auto update on here , I really don't know what else to do either...
Username: Crippledwarcook
Post Number: 93
You're the only one loosing channels..maybe you are retarded and don't know what the hell you are doing..I suggest you sit your fat azz down in front of the computer for about 3 hours and fcuking read....This is a really stupid post and could of been advoided if your fat azz would of read...ROTF
Username: Runnerguy
Pluto
Post Number: 39
OH MY!! aren't we a little testy today!! Maybe you should spend and hour or so with your wife today and get busy. It sounds like you haven't had any in a while!!!!!!!!!!
NDS Laboratory
Post Number: 54
No...Cripled War cok doesn't have a wife, girlfriend,or life.He is always this way. REAL SAD.to bad.
NDS Laboratory
Post Number: 55
When bin gets corrupted,asumming ur running pansats,do a factory reset,set up ur configurations,and blindscan that usually straightens all problems out.At least fer awile.
