What amp do i need
Username: Dsmith07
LaGrange, NC US oF A
Post Number: 209
i have my 6" JL Audio TR speakers in my front door and the JL Audio TR 6x9's in the rear deck
6x9's = 10-100 RMS
6"'s = 10-75 RMS
whats a good budget amp to use to power those ....200 budget.
Username: Tdawg30
Ohio USA
Post Number: 565
here is a very nice amp that will last and sound amazing........dont worry bout it being a refurb, they are just as good as new.
http://cgi.ebay.com/Kicker-ZX350-4-Multi-4-Channel-Amplifier-4-3-2-Car-Amp_W0QQi temZ280047305726QQihZ018QQcategoryZ79823QQrdZ1QQcmdZViewItem
Username: Tdawg30
Ohio USA
Post Number: 566
here better yet........
http://cgi.ebay.com/KICKER-KX350-4-ZX350-4-CAR-AUDIO-SPEAKER-AMP-AMPLIFIER_W0QQi temZ140050918878QQihZ004QQcategoryZ79823QQrdZ1QQcmdZViewItem
Username: Dsmith07
Post Number: 211
neither of the links showed up for me :-(
Username: Tdawg30
Ohio USA
Post Number: 571
huh? they work just fine for me
here is the item number 140050918878
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 1301
links worked good for me, but i don't know if that amp will be enuf power. sure they are underrated, but i don't think by that much. to get 100 watts x 4 @ 4 ohms then you need an 800 watts amp.
Username: Tdawg30
Ohio USA
Post Number: 579
do you see the range of rms there????????? it means between 10-75 and 10-100
not 10-100 10-100
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 1313
okay then where will you find an amp that puts out 100 x 2 AND 75 x 2????????? try this amp:
http://cgi.ebay.com/NEW-06-KICKER-ZX650-4-4-CH-AMP-650-WATT-REPL-KX650-4_W0QQite mZ180049550480QQihZ008QQcategoryZ79823QQrdZ1QQcmdZViewItem
a little over you budget and a little too much power, but a little too much clean power wont hurt.
Username: Crayola0
Wisconsin
Post Number: 1454
Try the Elemental designs stuff...all their amps are rated at 12.2 v.
