Silver Member Username: Dsmith07LaGrange, NC US oF A Post Number: 209 Registered: Jun-06 | i have my 6" JL Audio TR speakers in my front door and the JL Audio TR 6x9's in the rear deck 6x9's = 10-100 RMS 6"'s = 10-75 RMS whats a good budget amp to use to power those ....200 budget. |
Silver Member Username: Tdawg30Ohio USA Post Number: 565 Registered: Jun-06 | here is a very nice amp that will last and sound amazing........dont worry bout it being a refurb, they are just as good as new. http://cgi.ebay.com/Kicker-ZX350-4-Multi-4-Channel-Amplifier-4-3-2-Car-Amp_W0QQi temZ280047305726QQihZ018QQcategoryZ79823QQrdZ1QQcmdZViewItem |
Silver Member Username: Tdawg30Ohio USA Post Number: 566 Registered: Jun-06 | here better yet........ http://cgi.ebay.com/KICKER-KX350-4-ZX350-4-CAR-AUDIO-SPEAKER-AMP-AMPLIFIER_W0QQi temZ140050918878QQihZ004QQcategoryZ79823QQrdZ1QQcmdZViewItem |
Silver Member Username: Dsmith07LaGrange, NC US oF A Post Number: 211 Registered: Jun-06 | neither of the links showed up for me ![]() |
Silver Member Username: Tdawg30Ohio USA Post Number: 571 Registered: Jun-06 | huh? they work just fine for me here is the item number 140050918878 |
Gold Member Username: LbecknerTulsa, Ok Usa Post Number: 1301 Registered: Oct-04 | links worked good for me, but i don't know if that amp will be enuf power. sure they are underrated, but i don't think by that much. to get 100 watts x 4 @ 4 ohms then you need an 800 watts amp. |
Silver Member Username: Tdawg30Ohio USA Post Number: 579 Registered: Jun-06 | do you see the range of rms there????????? it means between 10-75 and 10-100 not 10-100 10-100 |
Gold Member Username: LbecknerTulsa, Ok Usa Post Number: 1313 Registered: Oct-04 | okay then where will you find an amp that puts out 100 x 2 AND 75 x 2????????? try this amp: http://cgi.ebay.com/NEW-06-KICKER-ZX650-4-4-CH-AMP-650-WATT-REPL-KX650-4_W0QQite mZ180049550480QQihZ008QQcategoryZ79823QQrdZ1QQcmdZViewItem a little over you budget and a little too much power, but a little too much clean power wont hurt. |
Gold Member Username: Crayola0Wisconsin Post Number: 1454 Registered: Jun-06 | Try the Elemental designs stuff...all their amps are rated at 12.2 v. |
